Valve adjustment
Schrijver Carsten
#1 | Geplaatst: 11 juni 2009 20:39
Hi everybody
Have a CX 500 custom year 82 .
Have some problems about adjusting the valves .
Motorcode is PC001E meaning that its a transistor type of ignition , meaning that i have the FS/F1 marks at the alternator - in the inspection holes for timing marks.
Anyone expert in telling me what mark to put it on , to adjust the valves correctly ?
The TR and the TL marks is also there , - but they dont seem to fit with the valves in closed position .
The valves have to be in closed position to measure the gauge at the valves . Therefore i need to know exactly what mark is correct .
cheers from Denmark
#2 | Geplaatst: 11 juni 2009 22:59
Hello Carsten,
use the T[L|R] marks, the "T"is for "Top".
If you're not sure you're understanding the manual (you've got one I suppose?) find the correct position like this :
- start on the right
- put a finger on the inlet valve so you can feel any movement
- slowly turn the crankshaft in the normal direction
- when you feel the inlet valves closing watch ut for the TR mark which should appear shortly after the inlet closing
- at TR the R piston is now at the top of the compression stroke, both in and out should be closed
- adjust valve clearance
- repeat for L(eft)
If you don't have a manual buy one or find one on the net. For the full story of the above with pictures see Rob Davis' webpages here
luck, Frans
 Valve adjustment
